Am setting for 857d everyone says it's low power.can anyone tell me how to setup for loud sound.they just can't hear me. Have made Mars jump.
For starters, totally disregard the Yaesu 100 watt output claim. I've found that any ALC trigger messes up the audio on AM. You can witness this with your power meter set to Average power instead of Peak power. You will see undesired back swing. Now if you set the mic gain low enough and the carrier power low enough as to not trigger the ALC at all, it will indeed sound pretty good. You should start seeing some forward swing. Now bare in mind this only happens at about 5-7 watts AM carrier and the mic gain way, way down.
If you understand that this yields you only about 20-25 watts of swing with a correct 1:4 carrier to PEP watts ratio, you now have something to work with. This is similar in power to a standard dual final export radio. As a bonus, the audio bandwidth is usually wider on a Yaesu than an unmodified CB when a quality desk mic is used. Audio bandwidth can be set even wider in the menu if applicable.
Treat it as mentioned above, get a Turner or Astatic power desk mic, run it into a clean properly sized linear amplifier and you may be surprised at the AM audio you can achieve with the Yaesu 857/897 series of transceivers.
Most of these radios will sound half decent with a little more than 5-7 watts of carrier, at least in my experience, I have run up to 15 watts before crap starts to happen in the form of ALC action. The service menu settings I mentioned above will allow you to change the point at which the ALC kicks in and will make a big difference in the sound quality on AM. Just for the record I do NOT recommend or condone changing anything within this service menu unless you have fully documented all settings and configurations before doing so. You can really turn your rig into an expensive paperweight if you screw up.
One thing most newcomers to an F rig do not understand is the carrier versus 100% modulated power. The vast majority seem to think that if the radio is rated for 100 watts then that is what they should see on their wattmeter when they throw a carrier on AM. That 100 watts is PEAK power and a fully modulated carrier is four times the peak value then it follows that the carrier should be no more than 25 watts to hit that 100 watt peak output on AM. I have seen, and heard, far too many radios where the operators tried to squeeze 75 watts or more of carrier and then complain about the crappy audio.
I saw that ALC setting in the service menu. About how far did you vary your setting?
I understand to document the original factory setting before adjustment and that those factory settings vary for each transceiver.
