Yeticom Optima Mk3 Frequency Adjustment?
buickid
304 'round the minigrass
Nov 22, 2012
237
143
53
Kona, Hawaii
Dusted off the Optima and put it in the truck. On SSB, the clarifier needs to be around 2 o'clock for other stations to sound "normal". Couldn't find a service manual online, anyone know which pot I can tweak to get back closer to 12 o'clock?
Thanks,
Trevor
Thanks,
Trevor
It's been a while since I worked one of these, but from memory it might not be that simple... If it's like the earlier Albrecht/Dragon (SY) designs, it would have a can for each of the 1KHz steps, between 1-5KHz, which are used to achieve each division in the VFO step range... Meaning that the alignment process involves 5 times as much 'work' to get it aligned properly, compared to a more 'traditional' radio. Having said all that, I could be totally wrong about the Optima. But the man who should be able to give some good advice on these is @magnuman - he might chime in.
Hi there Retro and Pez, got some photos to share. Pez, I think you're right about the separate cans. What would be the way to go about tweaking those? I have an old R2001 service monitor that's more or less on frequency, certainly enough for these purposes. I checked the radio on AM and FM, it's +/- 100Hz. Clarifier doesn't affect those modes, interestingly enough.
Thanks!
  • @ kingmudduck:
