B
BOOTY MONSTER
Guest
since im on a roll causing trouble , i thought id kick it up a notch and add thinking to the list of troubles i'm causing ...
imagine this .... a similar look to a super scanner , but with four elements rather than 3 , and no switching between elements , it would be strictly a omni antenna and the four elements are not driven , they are in fact just used as directors because ... there's a fifth driven element in the middle . each of the four outside elements would be %5 shorter and positioned out from the driven element the 3-4 ft that a director element would need . has this been tried or done before ? would there be any additional gain over a premium omni antenna ? would it work essentially as four 2 element beams simultaneously ?
thanks for entertaining my curiosity
