One of the references was my article as you asked me to share with you.
G5RV? If you are throwing a lobe in the direction desired then it is fine, but what about the nulls?
I prefer symmetrical antennas, using 1:1 current baluns at the feed point for current distribution. Easier to predict the radiation pattern of the antenna if it is symmetrical.
Feeding a wire at a current null will work for impedance matching, but then the question is, how efficient. I put up an OCF dipole for a visually challenged ham friend of mine. He needed an antenna that required no tuner and multi band , also on a budget.
He played with that OCF for a year, then I put him up a multi band fan dipole. Difference is amazing on the receive and transmit. The symmetrical antenna will work better than an OCF as the dipole can be oriented so the radiation pattern is in the desired direction, where who knows where the OCF lobes will be radiating at.
Once again I will refer to the half wave dipole as a standard. Hard to beat that half wave dipole.
Now I still would like to know how the laws of physics were changed so the "barn burner" 43' vertical was such a great antenna on 160 meters?
That 43' vertical will work on 80 meters just so so , it will kick butt on DX operating 40 meters.
In reality, ( yah back to that ) your vertical would be put to shame by a shortened trapped dipole for 160.
There are multi band dipoles 40/80/160 that use coax traps the home brewer can easily build that will fit in your lot size and out perform any 43 foot vertical on 160 meters ( and cost a hell of a lot less in $$$). Some bandwidth will be sacrificed as is the nature of using traps so it will need to be tuned to the portion of the band you want to operate in. It will not be as efficient as a full 1/2 WL dipole but the receiving station will be hard pressed to tell the difference.
I do not claim to know everything about antennas, anyone who does would be a fool. I can say I build them and test them, so no arm chair antenna guru here.
I also know anyone who claims a 43' vertical on 160 meters is a "barn burner" obviously has never compared it to a decent 160 meter antenna.
W4RNL has a great explanation of the top 5 backyard antennas, good reading.
Ham Radio Nation - Amateur Radio Social Network
