Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Click here to find out how to win free radios from Retevis!
That design here is commonly called a station master.
Possibly not the most efficient of radiators but seems to hold up well in our windy conditions.
Appreciate any thoughts and advice you may have on the subject.
HI Homer, I would like to build a half wave vertical. The one with the radiator fed with a tapped coil. How much radiator is below the tap in point? Does it matter? It would be much stronger if the aluminium radiator was inserted through to the bottom of the "C" clamp inside the PVC section which I think also works as a capacitor.
Thanks,
Dave
91dd018@gmail.com
GM...did you "see" all the adds on QTH.com...Ham selling off BIG Load of FT-901 accessories ...Not sure how good those prices are, however in "working" condition that stuff getting hard to find or replace.
73 All the Best
Gary https://swap.qth.com/view_photo.php?counter=1553341
