Yeah, I ran into that too. I just blanked out the digipath using spaces. To get the spaces, hit 0 (zero) twice.
I thought it should just use the digi path that you selected so I have the following;
1 Wide1 -1
2 Wide2 -1
3 Wide2 -2
4 SONT2-2 (for Southern Ontario)
I set it on 3 Wide2-2 pushed PTT and assumed that it would use 3 Wide2 -2, to my surprise when I got home and checked on APRS it showed my path as Wide2-1, Wide2 -2, SONT2 -2 sumoptimal path (because it send on so many paths). Now there is no way that I know of to get them out.
I really don't want to do a factory reset. I really hope RT Systems gets the programing software out soon, hopefully you could change it via the software if not you could just do a factory reset then restore all your settings and memories.
hehe...yeah don't do that As you found out, it uses all of the entries.
While editing the path, can you rotate the dial to get to the space character?
Yeah, I hate editing stuff on HTs by pressing the number buttons a million times. I'm looking forward to some sofware soon, too.
...XYZ0123456789ABC...
I just had to write it out?
If you press the three left buttons on the keypad when powering up, then press the F/W key, all your memories will be wiped out.
