Antenna Adapter??
KOBO
Wood Butcher
Greetings one and All..
I have a old magnetic mount antenna that I would like to use the base for testing other newer antennas, such a s a wilson 2000.
Is there a adapter to convert this older mount so I can use it with a 3/8 thread antenna?
TIA
Have a Magical Day
K
I use a similar base, and run a Wilson 1000 or a Sirio/RM Z-180 most of the time w/xlnt results.
It might be easier to buy a mag mount with the 3/8 x 24 thread. Seen them @ Fry's Electronics for a song. The coax was crappy; I'd change it out to a better piece though...
Never seen a converter as you asked/described . . .
It might be easier to buy a mag mount with the 3/8 x 24 thread. Seen them @ Fry's Electronics for a song. The coax was crappy; I'd change it out to a better piece though....
Yeah, that is probrobly the direction I will be heading in, just wanted to see though if I could make use of something I have had around......for maybe the last 30 or so years:eek:
Okey Dokey. thanks anyway.
Have a Magical Day
K
custom adapter
TIA
Have a Magical Day
K
Call Jerry Cash @ 330-896-3485 in Canton, Ohio- He has a machine shop, and builds an adapter for this situation. He also builds antennas and mounts.
I would like to know what that connector is called, and dont tell me it is a PL-259 or SO-239 because the polarity is reversed.
I know this is an old thread but since it has been revived, there is an excellent commercially available adapter called a Comet AD-35M SO-239 to 3/8X24 Adapter. I believe MFJ also has a version of this (MFJ-7710) that looks identical.
Sorry after looking again this appears to be the wrong gender.
  • @ nfsus:
    RFactive has left the room.
