test
You don't like my name in your sig no more?
No damit, I wouldn't do that to a buddie. I tried to add a little quip to your highlighted part, but apparently the powers to be have further limited the space available to add in the Sig area. When I tried to add to the original I got an error message limiting the text to 4 lines or less, and I think some lines can account for more that one line under the limit.
I was going to remove the "what'd she say" to you singing "My Ding A Ling."(y)
A Sigma4 model as specified in the Antenna Specialist manual. The only tweak in this model was done to the tip element to show the antenna resonant at 27.185, which set the antenna length at 28' 8" according to Eznec.
Why does the gain drop to 3.28db and the angle rise to 13 degrees when it shows the second total field model?
test
138879-marconis-eznec5-model-imax-radials-various-angles-9.html
http://www.worldwidedx.com/cb-anten...imax-radials-various-angles-9.html#post369850
  • @ nfsus:
    RFactive has left the room.
  • @ Tim Chambers:
  • @ AWP:
