radio and amp
rustyc
Oct 30, 2011
29
3
13
69
thinking about a 2x2897 trucker amp going with a uniden 78 what do i need to know about this combo what can i expect radio has been tweeked and tuned
they dont say anything about the drive...if they low drive and your uniden is cranked they may not work for too long
what kind of output is your uniden supposed to put out after tweaking? this way the forum can help you decide on an amp to run with it.
It's your standard class C comp style 2 pill, Rustyc they are actually 2879 finals. As long as the radio dead keys 2-3 watts and can swing 18-25 watts you should be just fine. That fatboy could probably handle up to 5-6 watts carrier but I don't like doing that. Plus since it does not have a fan no sense overheating the thing.
Hey RustyC, 250w will be a good loud setup.
if your into SSB get the uniden grant XL to drive that linear.
In my collection I have a Uniden Grant XL and it has a mild peak and tune.......I just use it for SSB. Doesn't do big watts but it is never the less blaring loud on AM with the original stock mic. I have it set to do 10 watts on SSB, can't be beat. If you got one you would be never sell it!
The last amp I would run with such a fine SSB radio like a Grant xl would be a class C amp that says Trucker on it. LOL. I doubt it even has a SSB delay unless you pay extra.
:laugh: Most truckers around here just run small amps if they run an amp at all.
fatboy also makes a competion 2x2879 amp radio pushes about 30 watts going to send it toscrewdrive at bells for amatch
how did this become a double thread, looks like u guys migrated over to the other thread.
Truckers here in California run serious power for the most part. only a few have i talk to running barefoot.
I'm a tender foot so I choose to wear choose.
  • @ Tim Chambers:
  • @ AWP:
  • @ wavrider:
    sea que sea que,
