ICOM IC-7000 programming cable help
Speaking in general terms only...
What you are describing is what is commonly called a "phono" plug whether you're using it for audio or not.
The plugs are typically, Tip-Ring-Sleeve (TRS) or just Tip-Sleeve (TS).
Tip-sleeve is usually a mono audio connection but may provide two conductor control such as "wired" IR, contact closure, etc.
Tip-ring has only one black stripe or insulator section.
Tip-ring-sleeve is usually stereo, left, right, and common or an XLR (microphone) connection in a different form.
TRS is also used for RS232 or serial connections, Tx, RX, and common.
Tip-ring-sleeve has 2-black stripes
... and something called: EasyPal not sure what it does but its installed.
then come and play with us on 14.233 & 7.173
it's pretty simple to setup the user options, let me know if you need any tips/ settings
Hrd keeps bsod everytime its open for 5 min. Wtf :(
Sent from Outerspace, on the DarkSide of X.
Gee, dunno 'bout that,.............. is it the (new ) Ver 5.1?
i was refering to EASYPAL..... a GREAT**Jump_im** digital SSTV program
YEA TRIED 5.0 &5.1 . I am not yet licensed for general. So I can't tx on 40m
  • @ nfsus:
    RFactive has left the room.
