invisible 10-11 met. antenna
If you are needing to put up a stealth antenna you will need to provide more information about your situation.
Are you in a house or apartment?
If an apartment ground level or what floor? Do you have a balcony, How big?
What is the construction of the building or house? This impacts the viability of attic antennas. For example stucco on wire mesh is a signal killer. Metal siding is not good.
Do you have a yard with trees?
There are a lot ways to hide a wire antenna everyone's situation is different.
Are you looking for local or DX?
Reactions: 3 people
end fed
this might work for you, a par 11m end fed antenna used with #26 magnet wire (very hard to see).
use a 20 foot telescopic crappie pole for vertical use or fishing line and run it from the roof to the ground for a sloper
You will need an invisible radio to go with that invisible antenna too.
images
Reactions: 3 people
  • @ nfsus:
    RFactive has left the room.
