Yup; that is the number on the board on this radio.Does this radio have the board EPT00JA-10Z?
I have the Uniden/President Export service manual with this board listed with the original PB042.
I'm sorry to be the wet blanket, dark cloud, whatever. But after reading this thread. I'm starting to think that the less technical buyer should avoid this radio entirely. If the radio comes out of the box off frequency and needing the receive fixed. That kind of cancels out its low price and makes it not the best choice for those wanting to buy a working radio..
According to this manual you need to change the 14.550MHz crystal to 14.745 to get up to 28.500 MHz
is it possible to mod this radio so it covers more of the 10 meter band ?
Here is the section of the Jackson schematic that has the AGC parts for replacement.
C31 is an electrolytic cap that will need to be removed.
The resistors R41, R43, and R47 will need to be changed out with different values:
Remove C31 (.47uf )
Change R43 (10K) to 1k
Change R41 (150K) to 270K
Change R47 (1.5K) to 3.9k
Gave it a quick but much needed freq alignment.
About to do the AGC mod next.
Works fine so far . . . Except for receive overload . . .
Top Picture: Just fired it up!
Bottom Picture: Shows the location of one electrolytic cap with a black mark on the top of it (I put the black mark on it to make it visible to all y'all) in the center of that photo. That is C31 - to be removed. The resistors that need to be upgraded are found to the left, right, and in front of that cap. You will find this location in the center of the radio just slightly twards the back. Easy Peasy...But NOT responsible if you do it wrong...
are you sure on the r41 270k ohm resistor,, another site has it listed as a 270 ohm resistor that is needed??
Uniden President Jackson-DX Mods (export version)
Wow! So which is it?
