WTB: Mobile Amp
TX-800 also known as the L.A.900 ,
this thing is a BEAST, has good ssb bias, sounds great on ssb. needs some major AMPS to run at full power, I was seeing 600w+ pep on my daiwa cn-801 and it was shutting down my astron 70 power supply,, from what I have read they need a full 80-100 amps to run full power
the inside looks as clean as the day it was built, out side looks a little dirty
$250 shipped,, also it is a low drive box and the only think I could find wrong was the on/off l.e.d. was inop , every thing else works as it should
figured you seen it,, sorry my bad,, I was also not thinking after you posted the wanted dx500,, those are a high drive right,, this one was a very low drive box.
I also seen that you replied to the tx 667v that was for sale, so I just figured you had something going on that box..
again im very sorry,, I should have pm'd you and verified that you saw my posts,,
probably would have bought it today as I have another low output radio it would have worked great with on the base. Oh well
    AKA- UDX122
  • @ nfsus:
    RFactive has left the room.
