Fine Tune CB
Status
Not open for further replies.
Met the Guy in Amarillo. He will insult you and he has to be the biggest narcissists I have ever encountered.
He actually believes the reason there are not many CB shops left like there were years ago is because his quality work has put them all out of business. That's pretty much a direct quote! This guy claims to be an ex-truck driver having driven more miles than I have, yet we are about the same age and I know for a fact he has been off the road doing his CB shop business for over 10 years so that is a lie. I do believe he did drive over the road but his years of service and mileage is doubtful.
Now he is self proclaimed CB engineering specialist? CB radios isn't rocket science. That's the equivalent of a tech school student working on lawn mower engines as opposed to a AES certified mechanic working on Industrial diesel engines.
The real reasons for the declining number of CB shops is because at one time, Truck drivers were some of the biggest users of CB's and many if not all CB shops were located at or near truck stops.That's a fact I can attest to from driving trucks over 30 years myself. Now they are few and far between.
Now a days, Many drivers don't own one or hardly ever turn it on if they do. Today's trucks are mostly speed governed so no need to watch for "smokey bear" (except for those 55 MPH communist states), and most trucks have electronic logs so no need to ask if the " chicken coops are open" more drivers use GPS so no need to ask "break 19 for local info".
The company I drive for has over 150 trucks based in Phoenix and I can easily count 40 or more trucks without a CB. Other forms of entertainment has succeeded the CB with today's drivers. The others I asked why they don't turn it on and the most common answer is they are sick of all the idiot base stations shooting skip blaring across what should be the calling frequency that is Channel 19 jamming the frequency up. That's pretty much a direct quote. That should make plenty of you guys out there proud who do exactly that.
Then there is the influx, if not taking over the trucking industry, all the foreigners from Europe, India, and Asia driving trucks who can careless about what a CB is. Then one day soon NAFTA will be fully implemented but at least I have seen many Mexican trucks using CB radios. Don't believe me? look at the reefer trucks with california and British Columbia plates, Majority of them drivers are Sikh's from India, no they are not arabs just because they wear turbans! Look at the trucks with plates from Illinois, New York, New Jersey, those drivers are from all over former Soviet block countries like Bosnia, Ukraine, Armenia, etc. hardly the CB radio truck driving stereo -type from years gone by.
But This guy at Fine tune (goes by "hard drive" on the CB ) believes otherwise along with his white list CB shop buddies that the decline of CB shops is because they have successfully put those other CB shops out of business.
To answer the OP's question, I only stopped in to buy a part not have a radio serviced. You have to wonder why he moves around a lot. I remember him being in Arizona, then Gallup NM and then to Milan NM before he went to Amarillo, now he is in North Carolina? Amarillo should have been the best market for him since it is located ideally to catch all the East to West coast running trucks and even though Amarillo might be a small town , it has always been a mecca for drivers with multiple truckstops, plenty of drug dealers, lot lizzards, titty bars, and yes, CB shops!
If you are just looking to fine tune your radio without adding parts and no repair, learn how to do it yourself. There is no magic to it. There are many knowledgeable people on this forum who you can ask for advice.
Checkout CB tricks.com. You can look up your radio and most of them have service manuals along with diagrams of the board showing which pots will adjust what.
My advice, If you want "big" modulation, don't clip the modulation limiter like most people do, Just turn up the AMC pot inside the radio all the way then use your mic gain for adjustment. Most newly purchased in the box radios have this pot turned too far down. Cb tricks will show where this pot is on your Galaxy 959 assuming that's your radio.
Get a better mic. CB base stations prefer D104 mics, Mobile radios prefer either Astatic or Road king noise canceling mics.
Check peak output power by turning RF power knob fully up with a good watt meter, then divide the peak reading by 4 and adjust your deadkey with the RF power knob at that value. (ie. if your radio peaks 12 watts, set deadkey at 3 watts.)
If you want more power, leave the radio alone and get an amplifier. Nothing is more ridiculous than gutting a radio up or adding circuity that wasn't intended to be there just to get a few more watts that really doesn't make one bit of difference on the other end.
Other than that, LEAVE IT ALONE!!!
I call that "Bill Brasky Syndrome".
Don't know what that means, I just gave an honest assessment about an individual and about what I experienced as a customer. I shouldn't have to be insulted and have to listen to someone's B.S. which is clearly out of touch because someone thinks he's a CB God. But I never said do or don't patronize him. I also gave a solid reason why CB use and CB shops have rapidly declined in the trucking industry and to give you guys a perspective what is taking place with drivers today. Sorry it was long winded.
There seems to be this same attitude with nearly every CB shop I have encountered. They tell you everybody else is a chop shop, those other shops don't know what they are doing, and when one of these guy's opens your radio covers and looks inside, the first words uttered is "who the hell worked on this".
I also gave advice for someone to learn how to do it themselves like many of you learned too. It's easy since the information is out there.
I was only shoring up what you said with a little humor. Bill Brasky was a fictitious character from some older Saturday Night Live episodes whose personality was as you described the repairman to be. He was the best at everything.
Thanks for clarifying! I haven't watched SNL in ages...
I watched his video about -125dBm on the President Lincoln 2. He mentions 7dB loss in the coax between the rig and the signal generator - WTF?
Reactions: Unit 194
https://www.facebook.com/finetune.c...E2ZDdhOGQ3YThhZWZiMmY4M2FhZjJlOGU0MjRiMjU2In0
Anyone ever used this guy? I think I will buy my next radio from him. His Facebook videos are really good to watch. He used to be in Amarillo TX. Then went to Naples FL. Now he is in Mooresville NC. He shows his work with the meeter and scope.
I have a Stryker 955 and President Lincoln 2, both tuned by Fine tune. The PL2 I purchased directly from him after the results of him returning the 955 to spec after purchasing from one of the majors. The major un named seller thinks it's ok to spread coils etc. No mods, bone stock, tuned to spec, no spread coils, nothing "pushed" or over driven. All done on a scope and spectrum analyzer, that's his deal. Clean is mean I think is his motto. Both radios get many unsolicited flowers, all reports are about the quality of the signal. Studio quality is the most common. I don't know Mark personally, only by our business dealings. Yeah maybe he has a little ego, but so what? I'm only looking at his results, I personally don't care as long as his work product is good. Could be the same as forum posters who don't answer the OP's actual question or just bought a part? He seems to have many of the smt radios figured out, I am happy with his work. Good communications, does what he says. Right now he has my 69FFB4, and when that's comes back, I will send him my 2995DX base. From what I can tell, the ego might come from day in/day out having to un-hack hacked radios to at least get them to function properly so he can tune. I do know in talking to him that he prefers new out of the box so the history is known and often has deals where he will ship new radio tuned to your door for a fair price. Hope this helps.
Reactions: Galaxy 959
He is now in Youngstown Ohio looking for a place to set up shop. I saw him yesterday.
Yea I got my radio from him. I consider him a good friend now. Awesome guy to deal with. He does it right and makes sure your 100% happy after you get it. Talked to him several times on the phone and a lot on facebook.
Reactions: rabbiporkchop
he is about the best in the country. if anybody find someone that does better work than he does I'll be the first one to try out this new super technician but until that day comes I won't let anybody touch my stuff other than him.
yes he is a little eccentric. and his confidence in his own work is a little extreme, but when you're on top of your game and you sit there listening to the airwaves and you hear radios that you worked on from coast to coast and that is all you hear coming in on skip it has a tendency to inflate your ego. so in this particular case his ego is justified.
Status
    May 15, 2024 @ 14:55 UTC
    Everything is El Dead-o. Joy!
    Please advise me to what is a good replacement mic for my SR-497HPC... Answer: 497 is "wired like Cobra", so many choices available. That radio does not need a power mic, so purchase a stock "coffin style" mic with a decent cord, like the ones that Astatic uses. The Superstar DM-507 is my go-to. https://www.ebay.com/itm/3050474478...adANq91JSiEEnz8EGqPJRBloTgEyaVsBoCtoMQAvD_BwE $12.99 + .99 cent shipping.
