i can't remember rob do they need a power source?Shure SM 58 or SM 57.
Yup.Thanks....wonder if they pair up with a art tube pre amp?
Nice mic...I have used this one and I loved it in the mobile!RF limited 2018 extreme. Turn the echo all the way down. They use a 9v battery. No phantom power needed and they are normally 4 pin cobra wired. And they have noise reduction as well that works well for mobile use as well as base use. Here is the one I have. Hope this helps.
What I want to do is use the shure mic and the art tube pre-amp and maybe art compression or just a eq...now I don't know how much sound will get through on a modified 29 but I have heard a shire mic and part tube pre amp and it has a very nice rich tone to it...I'm trying to improve my sound without over the top rack gear...I have also messed around with a behringer 802 through a 148 it was ok at best.. If all this doesn't work I will pull out a turner +3 and be good. I just like allways trying to sound very clean and clearI'm sure the shure mic will sound better, but I know the 208 extreme mics aren't bad for what they are. I just don't care for the echo. Easy fix, turn the VR pot down all the way. Anyhow, keep us updated as to what you do. You have me curious now as well. Have a good one and have fun. That is what it's all about!! And have a Good evening.
