This is a message from the founders of WSJT about a new experimental weak signal mode to have fun with:
Steve (K9AN) and I have developed a potential new mode for WSJT-X. We're calling the mode "FT8" (Franke-Taylor design, 8-FSK modulation). FT8 is designed for situations like multi-hop Es where signals may be weak and fading, openings may be short, and you want fast completion of reliable, confirmable QSOs.
Important characteristics of FT8:
Comparison with slow modes JT9, JT65, QRA64:
Comparison with fast modes JT9E-H:
http://physics.princeton.edu/pulsar/k1jt/ft8.png
We look forward to receiving your feedback.
-- 73, Joe, K1JT
Joe Taylor followed up with this note about frequencies for testeing:
It will help to have some initial frequency coordination among those testing the new FT8 mode in WSJT-X v1.7.1.
To help get things started, we suggest using the following frequencies:
Band MHz
160 1.841
80 3.579
40 7.079
30 10.141
20 14.079
17 18.105
15 21.079
12 24.920
10 28.079
6 50.313
4 70.094
Most of these suggestions follow a simple guideline: add 3 kHz to the commonly used JT65 dial frequency.
For 6 meters we suggest using 50.313, which should be consistent with band plans in all IARU Regions. (Six meter activity that's now on 50.276, world-wide, might be moved to 50.310.)
We are very much open to suggestions for changes in the above table.
-- 73, Joe, K1JT
- T/R sequence length: 15 s
- Message length: 75 bits + 12-bit CRC
- FEC code: LDPC(174,87)
- Modulation: 8-FSK, keying rate = tone spacing = 5.86 Hz
- Waveform: Continuous phase, constant envelope
- Occupied bandwidth: 47 Hz
- Synchronization: three 7x7 Costas arrays (start, middle, end of Tx)
- Transmission duration: 79*2048/12000 = 13.48 s
- Decoding threshold: -20 dB (perhaps -24 dB with AP decoding, TBD)
- Operational behavior: similar to HF usage of JT9, JT65
- Multi-decoder: finds and decodes all FT8 signals in passband
- Auto-sequencing after manual start of QSO
- FT8 is a few dB less sensitive but allows completion of QSOs four times faster.
- Bandwidth is greater than JT9, but about 1/4 of JT65A and less than 1/2 QRA64.
- FT8 is significantly more sensitive, has much smaller bandwidth, uses the vertical waterfall, and offers multi-decoding over the full displayed passband.
- We plan to implement signal subtraction, two-pass decoding, and use of "a priori" (already known) information as it accumulates during a QSO.
- Three extra bits are available in the message payload, with uses yet to be defined. We have in mind special message formats that might be used in contests, and the like. Your considered suggestions for use of these bits are very welcome!
-- 73, Joe, K1JT
Band MHz
160 1.841
80 3.579
40 7.079
30 10.141
20 14.079
17 18.105
15 21.079
12 24.920
10 28.079
6 50.313
4 70.094
-- 73, Joe, K1JT
