Who should I get it from? I don't want a clipped, overmodulated splatter box. I just want clean RX/TX with as much power and sensitivity as reasonably possible with a good alignment.
If your going to spend around $300 for a cb rig, consider a used hf rig As in a ts440 or 430
Thoes are excellent choices. I would like to add the Yaesu 757gx to your list. 73If your going to spend around $300 for a cb rig, consider a used hf rig As in a ts440 or 430
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
