I am not sure how to correctly hook this all up. The more I try to think it out, the more confused I am making it.
I have a Bearcat CB, an RM Italy 100 watt kicker mounted on top of it, an MFJ versa tuner, and a Texas Star sweet 16 (I think thats a dx 1600?). I wanted the rm italy kicker in here to feed in some watts to the texas star since its a high drive amp. The MFJ tuner is a must because my SWR is a tad higher than I like and the antenna is out of reach until the ground dries.
So, coax coming in from outside antenna, goes to the antenna side of the sweet 16, then from the sweet 16, coax jumper to the antenna in side of the MFJ tuner, then from the MFJ, coax jumper to the antenna in side of the RM Italy, and from the italy, a jumper to the radio?
Does this sound right? Or do I have this backwards? I am afraid of sending power into the kicker and popping it.
Thanks
Kevin
Thanks
Kevin
