ALS-500M Would YOU use one in the shack???
Mudfoot
Elmer
Jun 17, 2009
10,929
6,299
698
63
Southeast Ohio
I already have power supply to run it. I'd prefer to buy an ALS-600 with linear supply, but that would cost me over $1k more over the 500M. The radio interface cable for auto band switching would be berries.
Do you think the 500M running 12 volts is to dirty for base operation?
I would not use the 500 without puresignal wrapped around it..maybe the same for the 600. Im sure you've looked at the transistor spec sheets. -24db at 100 watts for the 2879 leaves a lot to be desired. The mrf 150s in the ALS 600 aren't that impressive either at -32 db. If you buy the 500 new will it come with Toshiba transistors?
Ameritron doesn't give IMD specs for either amplifier in their respective manuals. They do with their tube amps. Most of them are "-35 db or better".
I'm not sold on the solid state stuff yet. The guys running them seem to be wider on the waterfall.
Reactions: Mudfoot
Mudfoot, I respect everything already said here. I have one and have used as a base. Been hitting it with 70 watts that puts me close to 375w out(narrowish). I have really just started with HF and has really helped. Just checking into nets and stuff. If conditions were better the width would be a no go. Until the bands improve I will continue to use it. Hopefully by then I may have something much cleaner.
Reactions: Mudfoot
if i could find one for $50, I would run it...lol
note he put over 100 watts into it.
i know i know the whistle:whistle:
Reactions: 2NC995
lol, it's all good and fun. looks like the sweet spot on daves amp occurs when driven with 62 watts.
again dave got a good deal on his so, off to some ham fests...
Here is an ok power supply to run your amp. A bit pricey but live large..
Reactions: Slowmover
