Well, if you hold the FUNC button while power on it is the factory reset.
Crap!
But the CB band is still band 4, so maybe there is a jumper inside or something.
Hold the COLOR button and power on is the engineering menu. Scan is some kind of function test.
If you buy it from Scott's he might tell you how to do it. He was smug about the K-PO conversion in his videos, But when I got it, there was an extra piece of paper in the box with instructions how to do it. You could probably call him and see if he would send instructions with the Stryker, which I suspect he would.
I am not quite sure what the engineering menu parameters are exactly. It appears to be frequency adjustments, power levels, modulation, etc. Basically the things that used to be adjusted on the board itself.A
What, exactly, is the engineering menu? I would love to have access to the service menu. Don't know what the engineering menu is.
Thats what I'm looking for. Do you know how to access it?I am not quite sure what the engineering menu parameters are exactly. It appears to be frequency adjustments, power levels, modulation, etc. Basically the things that used to be adjusted on the board itself.
Edit
So basically it is the service menu.
Word of warning, before you change anything write down the default values first.
May be helpful.
Can't you " lock" the clarifier with the programing ?Is there anything besides convert, maybe lock the clarifier that should be done to a V2?
Might be able to. My seller was gonna do it, good to know.Can't you " lock" the clarifier with the programing ?
On the anytone clones you can select that option in the menu.
Ok I guess dude is sort of giving me a quick simple start at it, that works.Yes, the clarifier is in the main menu.
