I have a board from a junk Yaesu FT101B. I am trying to identify one of the filters . It is unmarked completely no stamps no numbers. Can anyone tell if it's for AM or CW?
Thanks Nomad. I'll give it a try in a couple weeks. Will let you know the outcome. 73Plug it into a radio and listen is the quickest way. The unmarked filter on the top of the board will be active when the radio's mode knob is set to "CW".
Listen to the pitch of the noise in the receiver audio. If the pitch increases in CW mode, it's probably the AM filter. A wider filter lets higher audio frequencies squeeze through.
And if the pitch of the noise get lower, it really is a CW filter. They are normally too narrow to use for any voice mode.
But an unmarked part can be identified only by what it does. It will either widen the bandwidth of the receiver if it's the AM filter, or narrow it because it's a CW filter.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
