I just bought a lincoln II v4. The receive is a lot noisier compared to my galaxy 959. Does anyone know where I can download a service manual?
Also be aware that ASC operates in AM/FM mode and when the Squelch is full CCW = ASC enabled. It will show up on the LCD display. Turning it to 8:30~9:00 will disable it and the readout will show "SQL 0". ASC does not work in SSB, so in that mode Squelch full CCW = Off.I just bought a lincoln II v4. The receive is a lot noisier compared to my galaxy 959. Does anyone know where I can download a service manual?
Not the same as the V4 but it does look close. Thanks. I will keep looking.attached - not sure it's same version, but there you go.
I found a way to adjust transmit frequency without using the spooky engineering menu. I used an SDR for receive and fed a 1khz tone off my phone app to correct the frequency. Using the clarifier menu item set to "t" (transmit only) I adjusted the tone to match on the SDR with the clarifier knob. I then returned to the clarifier menu item and set it back to "r" (receive only). The changed transmit clarifier setting was then saved and the transmit frequency corrected.With both USB and FM 50hz low, sounds like you could have adjusted menu # 4 and brought everything up by 50hz with a single adjustment. Unless the other modes were spot on.
P.S. you always want to turn your clarifier off before making freq. adjustments so it doesn't influence the transmitted signal.
Interesting. What happens when you turn your clarifier Off? Does the TX freq. shift? Also, why do you think your SDR is On frequency and your radio Off?I found a way to adjust transmit frequency without using the spooky engineering menu. I used an SDR for receive and fed a 1khz tone off my phone app to correct the frequency. Using the clarifier menu item set to "t" (transmit only) I adjusted the tone to match on the SDR with the clarifier knob. I then returned to the clarifier menu item and set it back to "r" (receive only). The changed transmit clarifier setting was then saved and the transmit frequency corrected.
I realize this is slightly off topic but I couldn't find a better place to post my "discovery".
I hit WWV spot on with the SDR. The frequency offset sticks with the clarifier at receive only or off. If I had the guts I'd check the engineering menu to see if the values update.Interesting. What happens when you turn your clarifier Off? Does the TX freq. shift? Also, why do you think your SDR is On frequency and your radio Off?
I did start a new thread for this.
Thank youattached - not sure it's same version, but there you go.
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
