IC7600 Display not working
Hello my friend, not working display
My question is, what are the right voltages Pin 4 and 6?
I guess mine are wrong
What's a voltage in 1, 2, 3 ?
Mike
Reactions: 357
Hello Dear friend, here is the measurements. Thanks a lot for your comments
Hello, once I received the Q404 I changed it and I not working the display. I send you the voltages around Q404 for your consideration
My problem is I do not have a circuit with detailed information to trace all the voltages. So far, you were helping me. And I don't want to bother you, but if you have all the voltages around I need to check, Please send it to me, I can check all of them and then we can discuss about it.
I checked all the Display unit and not 5V to LCD. My question is where it comes this 5Volts?
J604 Pin 12 ???
