stryker sr 955 hp version II
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
3,835
5,095
523
69
my new 955 had the dreaded frequincy selector problem. i write the place and part number of a better 1 posted here.
somebody that cleaned my area threw several of my notes away with the selecter information.
if the poster or whoever read it can you kindly get me that information?
shop where i got mine got new 1 from stryker. it worked great 2 nites n it now wont change channels.
this is the only fault i see with my new radio
To my knowledge there is no replacement channel selector for the V-2 other than the OEM. I've had mine replaced already, and the new one is not great. There is a different encoder for the V-1, but they are not interchangeable with the V2.
Reactions: Rwb
somebody posted an interchange selector not exact same but said it would work great after installing it
HHHmmm... not aware of that for the V2. Maybe someone will come forward and explain.
Im thinkin that 1 that posted it prolly got first version mixed with version 2.prolly call stryker order 2 n be done
Well you already know there is only one person that knows more about the Stryker than even those who designed and built it.... That's a question only the "Chosen one" can answer.
You'd have to venture into the land of the pixie dust to get the only real and true answer for the Stryker channel encoder.
Yeah, the little soft-drive had a replacement for the V1, with his "special" knob shown on a few vids. The factory V2 selector was supposed to be a bit more robust with tighter detents. However, I have had issues with the V2, and still do shortly after replacement. They're going to have to address this situation soon.
Reactions: Rwb
im thinking they are full of grease. was thinkin heat gun low setting n get er warm n try. or get a new 1 n heat it up then hope grease melts
Question.
I don't own one of the new 955.
Do they have little swing from a low carrier like the anytone flavors?
I'd assume so being they essentially the same inside as the q5n2, but maybe they've done something different for Stryker.
Reactions: Rwb
Question.
With the proper tweaking you make them swing as you wish. It's a matching game between the HI and LOW output power, and the HI and LOW modulation settings. Once you get the feel of setting them up, it's a breeze.
    BLACKOUT HF
    May 15, 2024 @ 14:55 UTC
