Receive loss
MadisonMod
New Member
Jul 16, 2023
44
7
8
54
Hello. Can someone explain why my receive goes quiet after transmitting on my radio? If I click the microphone button on and off, then the receive comes back. I have an amplifier in line, maybe something is going out on the amp ?
take the amp out of line. if it stops doing it then the issue is the amp relay sticking. If your using a preamp built into the amp, turn that off as that could be the relay that's sticking.
Reactions: Cable Guy
take the amp out of line. if it stops doing it then the issue is the amp relay sticking. If your using a preamp built into the amp, turn that off as that could be the relay ithats sticking.
The radio does receive properly without the amp. I will see about ordering a new relay for the amp. Thanks much
  • @ Tim Chambers:
  • @ AWP:
