Which CB Shops are still accepting mail-in repairs?
Not much of a tech if he only turns a screwdriver.
That means he is a screwdriver jockey. not a "tech"
Disclaimer: Mark Sherman of Fine Tune CB Shop
is a charlatan, or "mountebank"; RabbiPorkChop is his internet soldier.
A charlatan (also called swindler or mountebank) is a person practicing quackery or some similar confidence trick or deception in order to obtain money, fame or other advantages via some form of pretense or deception. Synonyms for "charlatan" include "shyster", "quack", or "faker"
"Mountebank", Italian phrase "monta in banco";
Literally, referring to the action of a seller of dubious medicines getting up on a bench to address his audience of potential customers.
https://en.wikipedia.org/wiki/Charlatan
To answer the OP's question, I only stopped in to buy a part not have a radio serviced. You have to wonder why he moves around a lot. I remember him being in Arizona, then Gallup NM and then to Milan NM before he went to Amarillo, now he is in North Carolina? Amarillo should have been the best market for him since it is located ideally to catch all the East to West coast running trucks and even though Amarillo might be a small town , it has always been a mecca for drivers with multiple truckstops, plenty of drug dealers, lot lizzards, titty bars, and yes, CB shops!
http://www.worldwidedx.com/threads/fine-tune-cb.181877/
Sounds like he might be moving around to avoid either the FCC the IRS or his irate customers.
Both radios sound identical being recorded through one radios talk back. Ok got it. Let us know when Sherman starts repairing radios again.
That's misrepresenting what I said.
Obviously my TalkBack is going to sound differently than his over-the-air transmission. You can't hear my over-the-air transmission in that recording so how would you know what both radios sound like over the airwaves?
I simply said both radios sound identical over the airwaves. A little bit of Common Sense would be in order.
Those are your intentions. My intentions are to share my real world experience.
You do realize that I have found at least a dozen people that you have intimidated, harassed, belittled, ridiculed....
So when you are doing these things it's so you can "share your real world experiences?"
Were you belittled, harassed, intimidated or the like by anyone?
If these are your real world experiences that you are echoing back to others then we need to get you some help. You should not have to feel that way let alone channel it to others.
You are not alone. You can get help.
http://dhs.pa.gov/citizens/reportabuse/dhsadultprotectiveservices/
Maybe....Maybe not. His contact information for his service is not readily available.
The "exclusivity" is one of his sales tactics used to lure people in,
("if it is hard to get, it must be of good quality" fallacy)
Also it could be a tactic to distance himself from the fed or people wanting to return the treatment & scrutiny they have suffered under him or his fan base.
(foul language warning, NSFW)
RPC, watch 1:21 to 1:42.
IMO, the "FineTune Challenge" has become a meme. Much like the "TidePod Challenge" only more entertaining.
Meme: an idea, behavior, style, or usage that spreads from person to person within a culture
  • Memes (discrete units of knowledge, gossip, jokes and so on) are to culture what genes are to life. Just as biological evolution is driven by the survival of the fittest genes in the gene pool, cultural evolution may be driven by the most successful memes.
    —Richard Dawkins
Reactions: Unit 194
Just going by what you said. You are all over the place. Ok they sound identical. We will take your word for it.
I have been scouring and searching and I can't find many that are enamored with Mark Sherman or Scot Johnson.
They seem to have a third accomplice and possibly a fourth.
The rabbit hole on these guys is getting pretty deep.
Just wading thru forums and google search results shows me that these two have been launching attacks at various people for nearly a year.
And they use forums like this one to find their targets.
  • @ Wildcat27:
    63Sprint has left the room.
