Yes, you can bypass the driver easily. Remove the resistor between input of 4 pill out the ouput of driver. Disconnect power to the driver stage. Then disconnect the coax from the variable. The center wire goes to the input of the 4 pill/ transistor section. Make sure you solder the braid of coax back to ground also. If not, tuning will be greatly affected. That's it.
