Just thought about this, and haven't tried it yet, but will be opening up the 2000 in a day or two for another mod, and might give it a shot.
I thought i'd put it out there to the great minds of this forum for a little perusal before i do.
so, the AUX jack on the 2000GTL is meant to allow you to hook the radio up to a tape recorder in order to record both the received, and the transmitted signals of the radio.
There is another use for it, and that is to connect it to a home stereo system and equalizer in order to tailor the audio to your liking, and maybe filter out some extraneous noise.
The issue with doing this is that as soon as you key up, you have talkback through those speakers, and in my case, a whole lot of feedback.
My idea is to connect the transistor controlling this jack (TR51) to a receive only voltage source.
as can be seen in this diagram, the collector of TR51 is connected to pin 1 of the voltage regulator through a couple of resistors:
i would think that if this connection were moved over to pin 6 of the regulator, that the jack would only be active on receive, thereby removing the talkback.
so, am i missing anything?
has anyone else tried this?
thanks for any input.
