2006 Cobra 29 NW LTD Classic Audio IC YD1022
2315 Robert
Grateful
May 28, 2016
276
150
53
52
Central Coast CA
Does anyone know where I could get a YD1022?. If not does anyone know that if I used a 7222 and changed the appropriate parts out on the board if it would work? Does anyone know how to use 2 five leg 2033 to replace the YD1022? Thank you.
a couple years ago I bought some from this company. they do not show to have any now but you might email them if you do not find them. the ones I got from them worked just fine.I even bought a couple mb8719 PLL's from them that were good.
https://www.utsource.net/
Thank you for the reply. I have seen that change out document going from the TA7222 to YD1022. I will need to spend some quality time with my magnifier before I try to go "backwards". It seems like I could pull a couple of diodes, change some resistors and caps and use the TA7222. The search for the YD1022 is a tough one. Thanks again for the reply.
