23-cm BiQuad Antenna with Lips
C2
Aug 3, 2005
2,408
79
158
I had been inspired to try ATV (amateur TV) on 23-cm and built this antenna to feed an old 10-foot C-band satellite dish I had.
The design is based on plans for a WiFi biquad that I found on the Internet:
Biquad Antenna Construction
I scaled these dimensions for my frequency and made adjustments along the way.
I first bent a length of 12-guage solid copper wire (common house wire), a total of 19.5 inches, into a shape to make two squares with the ends at the center of the long dimension.
Then I made a reflection plane with an additional 1/2-inch on each side to help the directivity (the lips).
I fed the antenna with some semi-ridged scrap coax and adjusted the offset from the reflection plane for lowest SWR (about 1/4-wave away).
I’ve added an SMA connector to fit with my 23-cm ATV station.
Below is an SWR plot I made with an antenna analyzer. The SWR shown is a bit off as the station it is used with is a 75-ohm station and the analyzer is 50-ohm. It works well nonetheless.
I also made gain measurements comparing to a reference dipole antenna from a distance of 30 feet and measured a 9.9 dBd gain at operating frequency. This comparison worked well given the flat dipole's nominal impedance of 72-ohms.
I’ve been most pleased with this design and have even made a DTV antenna that works just as well as commercial antennas. I would suggest one for directed 70-cm operations over many of the popular yagi style antennas, as I believe they have a better F/B ratio.
C2,
Would you mind going into some more detail on your ATV station and what type of activities you're doing with it? In all honesty, I understand the principles of ATV, but I've never really talked to anyone about the details of how to do ATV and why I would want to try it. Are there a lot of stations in your area doing it?
Also, how are you making that main element stand off from the reflector? I can't quite figure it out from the pic.
Nice work.
I built a double biquad and use it for 1900MHZ reception on wireless ISP.
I used solid metal for the reflector and put it on an old hughes net parabolic dish.
Hard to beat those biquad at such high frequency with a parabolic reflector.
C2,
The main element is soldered to semi-rigid coax. The outer shield is usually tin or copper, and I just soldered the coax to the screen. It is not super strong, but strong enough for what I was doing. I will add some standoffs at the tips to secure the element better.
ATV was more experimenting than regular use. I have a 23-cm station from low power modules that I bought off ebay from a Norwegian fellow. Similar to the ones here:
ATV Special Offers, Pakage Deals and Offers Amateur Televsion
Just plug in your monitor, cam, and mic and you can run a full duplex station. My stuff is boxed up now, but I was just using my TV and point-n-shoot cam.
My area has K6BEN, a 23-cm repeater station that downlinks to one of the 70-cm ATV stations, and it can be received on a regular CATV with just rabbit ears. He runs a net every Wed. night and is crosslinked on several repeaters in 70-cm, 1.25- and 2-meters.
The Silicon Valley ATV Group
I tried to hit his repeater, but I think there is a building in the way...
