How much drive can a single 2879 drive section safely handle and still put out nice clean sound?
It's in a 1 driving 4. All 2879 DEI pills.
Sent from my SCH-I545 using Tapatalk
That would depend on the amp. You are going to need to adjust the radio's carrier power until the amp keys about 200 watts and it'll sound fine.
A single 2879 is too much drive for four 2879's (imo) so they typically swamp the drive. I think a Cobra29 is plenty for a 1 driving 4.
A Toshiba 2SC2879 is speced at 10 watts of drive max. IIRC. More will simply create more crap out unless the input is heavily swamped. With a single 2879 driving four there is far too much drive available to the final four if a clean signal is what you are after. If all you want is crunchy audio and swinging meters then 40 watts into a 1 X 4 will do the job.
If it was me, I would go with a straight 4 pill class B amp with that radio.
I'm using a 29 and straight 4 design, but I think he meant a straight 4 with the 55 ...... which would be fine as well.With the 29 or the 55?
Either 1 but it would work nice with the 55.With the 29 or the 55?
