#29 Vintage gear I picked up for future teardowns and restore
Radio Tech
Radio Operator
Sep 9, 2008
858
310
173
62
North Carolina
www.gokarters.com
In this video we take a quick look at some vintage ham radios and test gear a friend gave to me today. This is what we have:
Kenwood TS-520 hybrid HF rig
Heathkit DX-20 CW transmitter
Eico model 215 signal generator
Heathkit HP-23 power supply
HP model 410A Volt OHM meter
I will used these in future repair and restore videos
Reactions: Robb
Is it possible to get 1-50uV out of that generator; or hold freq stability?
Good question Robb. We will find out when I tear into it.
Here are the specs:
Eico 315 RF generator
Provides a tunable RF output between 75kHz and 150MHz with 1% accuracy.
Utilizes a 6-position range switch and a variable frequency vernier.
Audio output of 400Hz is provided.
RF output level is selectable via a 4-position multiplier switch with
a continuously adjustable attenuator (pot).
Tubes: 7F7, 6C4, VR150, 6X5
Cabinet Size: (HWD) 13" X 12" X 7"
Weight: 20 lbs
$39.95 (1962)
Nice score. The Kenwood TS-520 boat anchor is definitely worth restoring (y)
