2sb817 upgrade? Dual final 959 needs a better regulator.
Discussion in 'Amateur Radio Modifications' started by Alex Faught, Mar 24, 2017.
  1. LeapFrog
    LeapFrog
    Expand Collapse
    χρυσοποιία
    Feb 15, 2016
    1,339
    430
    LC,
    when I get some time on my hands I'd like to test this, I'll use a DX88HL with BJT's;
    I will leave the radio configured the same way for both tests (and for equal duration/output) AM mod transistor being the only factor that changes.
    I do not doubt your EE professor for one moment, but I'm stubborn and would like to test the theory in practice (so that I may post objective measurements here). :cool:
    Onelasttime,
    Having observed a sizable difference in output (from my amplifying device) by simply increasing the output of the exciter, I see why some people would want modifications made to the radio.
    Not all high-power modifications are performed to an equal degree of success,
    In regards to spectral purity. :sneaky:
    #16 LeapFrog, Jan 6, 2018
  2. unit_399
    unit_399
    Expand Collapse
    EL CAPO
    Jun 17, 2008
    1,331
    553
    LC is correct.
    When a transistor conducts current between collector and emitter, it
    also drops voltage between those two points. At any given time, the
    power (heat) dissipated by a transistor is equal to the product of the
    collector current and the collector-emitter voltage (neglecting b-e
    current which is negligible).
    In a given circuit, (regardless of what transistor is used) the amount of
    power (i.e. HEAT) dissipated by the transistor will be the same since
    the collector current and the voltage across the collector-emitter are
    unchanged. Utilizing a transistor with a higher dissipation rating just
    means that it will handle more heat ... it will NOT run cooler.
    To protect the device obviously an external heat sink should be used.
    On my dual final galaxy radios. I cut a 2 sq. in. hole in the chassis
    behind the 2SB754. Then I fab a finned aluminum heatsink to fit the hole and bolt the transistor to it. The aluminum dissipates the heat much better than the steel chassis.
    A word about transistor substitution. The DC current gain of the
    2SB754, 2SB817, and TIP36 are not the same. The SB817 and TIP36
    have higher current gain specs, and if they are used as a replacement
    then their base drive should be reduced accordingly.
    - 399
    LeapFrog likes this.
  3. LeapFrog
    LeapFrog
    Expand Collapse
    χρυσοποιία
    Feb 15, 2016
    1,339
    430
    Thank You 399, your description {along with the community consensus} convinced me to not even bother testing this (it makes sense now).
    No, now I see that would be a waste of time.
    If I want/needed a beefier part I know what to do, but it will create the same amount of heat and offer no real thermal advantage
    Am I wrong on this one, or have I picked up on a clue?!
    #18 LeapFrog, Jan 6, 2018
  4. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    509
    374
    Seems to me that a part that dissipates the heat better while producing the same amount should itself stay cooler than a part that holds onto and accumulates the heat, am I missing something here?
  5. loosecannon
    loosecannon
    Expand Collapse
    Mar 9, 2006
    2,693
    922
    yes, the part you are missing is that just because a part has a higher current rating, does not mean that it dissipates the heat any better.
    It is still the same amount of current, flowing through the same size part, on to the same heatsink.
    check my post above where we asked an electrical engineering professor about this.
  6. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    509
    374
    This part here seems to imply that while the total heat in the system may be the same the important parts should be cooler, with the back of the transistor being the part that's in contact with the heat sink wouldn't getting the heat to that part of the transistor more efficiently be a good thing?
    ShadeTreeMechanic likes this.
  7. loosecannon
    loosecannon
    Expand Collapse
    Mar 9, 2006
    2,693
    922
    that only matters while the part/heatsink is actually heating up, and at some point during that process, the heat created on the heatsink begins to heat the part back up.
    again, im not the expert on this, but the lesson we got from the expert was that we would not notice the slight decrease in the heat on the part itself because of this.
  8. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    509
    374
    OK, I think I got it now. The new part doesn't eliminate the bottleneck, it just moves it. Eventually the whole shebang is going to reach the same temp anyway.
    Thanks.
    loosecannon likes this.
  9. unit_399
    unit_399
    Expand Collapse
    EL CAPO
    Jun 17, 2008
    1,331
    553
    LC -
    I hope you didn't mean this the way I read it.
    The heat sink does not create heat. It absorbs heat produced by the transistor. If the heat sink is of adequate size, and correctly fastened to the device, it will heat up until it reaches an equilibrium point. This is the temperature where the heat absorbed by the sink is equal to the heat radiated by it. If the device produces more heat than the sink can radiate, the device will eventually fail. At this point, there are three choices: 1. Install a more efficient heat sink, 2. Replace the device with one that has a greater dissipation spec, or 3. Both.
    This is why I install an finned aluminum sink on all of my export rigs. Using a sink like this will actually allow the transistor to run cooler. The same amount of heat is being produced, but the more efficient sink dissipates it faster so the equilibrium point (heat in = heat out) is reached at a lower temp.
    The Galaxy 959 converted to dual mosfet finals (as described by the original poster) also needs to have a heat sink installed on the back of the radio to protect them. I use the sink from the RCI 2950 because it is the right size and is readily available. I cut holes in the steel chassis so that the transistors can be bolted directly to the sink. This allows the heat to be dissipated more efficiently. 73s.
    - 399
  10. loosecannon
    loosecannon
    Expand Collapse
    Mar 9, 2006
    2,693
    922
    I see how you could interpret it that way once i read it again.
    I meant what you better explained above.
    That they reach a point of equilibrium and equalize in temperature.
    unit_399 likes this.
  11. Ranch55
    Ranch55
    Expand Collapse
    Jan 18, 2016
    94
    31
    They can only reach a point of equilibrium if the heat sink also generates/creates its' own heat, which it cannot.
    Whenever the output power ceases (unkeying), the heat will also cease rising. Shortly after that point, the temperature will stabilize for a time, then start decreasing as the heat sink dissipates it heat into the surrounding air.
  12. StrangeBrew
    StrangeBrew
    Expand Collapse
    Aug 15, 2011
    509
    374
    So I guess for all practical purposes the regulator and it's heatsink work together and for best results they should both be upgraded together.
  13. ShadeTreeMechanic
    ShadeTreeMechanic
    Expand Collapse
    New Member
    Oct 23, 2017
    40
    15
    I am learning alot here. Let me see if i have this straight. The main idea of having a larger transistor package is to be able to conduct more heat away from the junction and into the heat sink. A bigger conductor can carry more heat. Heat seeks cold. Cold is absence of heat. Heat will move through a conductor to where it is colder. The spot that is colder is the heat sink. The junction stays cooler for a given load because the heat is removed more efficiently because of the bigger conductor.
  14. ShadeTreeMechanic
    ShadeTreeMechanic
    Expand Collapse
    New Member
    Oct 23, 2017
    40
    15
    Equaliberiam meaning heat in equals heat out.
  15. Chevboy0167
    Chevboy0167
    Expand Collapse
    New Member
    Apr 5, 2017
    56
    17
    To me, sounds like the only way to remove more of the heat created by this "upgrade part", is to mount it on the rear of chassis, next to the finals, and bolt it to the already factory supplied heatsink. Then run some wires to the board where it came out of originally.
    At this point, if you hotrod the radio or are long winded, you may need to replace the factory heatsink with a lager unit like they use on the Stryker/Magnum radios which may require some drilling.
    Thoughts???
    binrat likes this.
Share This Page
