3cx1500d7
2112
Dec 22, 2006
48
can someone tell if the is a replacement for the 3-500z from what i read the only thing dif is the amps dose anyone know???? thanks showtime in ga..
http://www.g8wrb.org/triodes.php
Not even close.
They may be interchangeable in the socket, but there's a world of difference beyond that. Just start with the power supply required for the filaments. Both require 5.0 volts. The 3-500 filaments require 14.6 amperes. The 3CX1500D7 takes 30 amperes.
Plate voltage? The 3-500 is rated around 2800-3000 volts. Compare that with 6000 for the D7.
Not even close.
  • @ ShadowDelaware:
  • @ nfsus:
    RFactive has left the room.
