69FFC2/4 Frequency expansion
VA3ES
Old Buzzard
Oct 30, 2010
645
81
38
Ottawa, Ontario
RCI 69FFC2/4 Frequency expansion
EPT990014A chassis
1. Bottom of main board, solder side, Remove 100 ohm 1/8 watt resistor on bottom of PCB in 4008-divider area.
2. Top of main board, component side. On J30, move the shorting block to pins 2-3.
3. Follow the Hi/Lo switch wire down to the main board and unplug it from J5.
4. Move it to J29, in front of J30.
5. Radio will now cover 24.265 through 29.655 in 12 bands (6 LO, 6 HI).
  • @ nomadradio:
  • @ ShadowDelaware:
  • @ c316buckeye:
    no conditions in ohio
