830 coversion?
T
Tumbleweed
Guest
Can this radio be coverted for use on 11m?
I seen the warc conversion, but this one doesn't show
the 11m band on aux.
Jerry
CDX350
TW350
</p>
if you a talking about the Kenwood, i am 95% sure it can be, ask this guy, he is a PRO on that radio!www.d104mods.com/
</p>
Yes, I'm talking about the Kenwood 830S. It has the warc mod, but there's not display for anything in the 11m.
I emailed him, thanks.
Jerry
CDX350
TW350
</p>
Sorry this took so long...
Bottom cover off, radio upside down--
-bottom up
-pll board to right of vfo
-locate fixed wire plug ---left side of pll--- six wire plug
-second wire from front must be cut-white/purple
-optional single pole switch in series makes it switchable
-coverage will be 26.435 to 28.055, but display will read 2 megacycles UP, from 28.435 to 30.055!!!
Obviously different from the previous post, but I know that it was done to my friend Dennis' radio and it does work.
</p>
Thanks Highlander, that did the trick. Have you heard any way to get it to work in the aux position?
Thanks,
Jerry
CDX350
TW350
</p>
  • @ Tim Chambers:
  • @ AWP:
