I was hoping for a bit of help here guys.
I have a 959 that has very low audio and modulation.
Low and high carrier settings adjust fine from 1-10 watts.
I have replace the driver, and both finals, and checked voltages across the board. Watching it on the scope while turning vr16 shows very little change.
Injecting the 30mv, 1KHz singnal while on SSB causes some very erratic movement on the radios output meter as well as with the mod signal on the scope. However if I turn my fine adjustment up on my generator, this seems to steady out.
PA seems to be putting out but RX and TX are just very weak.
I'm leaning towards IC9 but at this point, I'm just not sure. Been working on this thing for a few days now and could really use some advice.
Thank you for any and all replies.
