99V2 channel board
Kung Fu Panda
Jul 5, 2018
36
9
18
51
Anyone know the part number for the transistor that goes in front pin three on the 99V2. See pictures below. It was burnt to a crisp. Thanks in advance.
OK, I couldn't find anything in the 99v2, but I think I might have a handle on what you need. That isn't the channel board, but the board with the mic jack and the VR's on the front of the radio.
I'm using the 93t as a guide and that transistor is on your mic line.
I think the highlighted part is what you are looking for.
I was thinking the same thing, thanks for the reply... I have looked for that part and cant find it. mouser and Digikey has them but on backorder of course..
Reactions: 999
This should be what you're looking for. What I don't know it the size of the transistor. There are 3 sizes listed and I picked one and found it at Mouser.
http://www.cbtricks.com/radios/galaxy/datasheets/transistors/pdf/dta124ee.pdf
https://www.mouser.com/ProductDetai...MCC/DTA124EUA-TP/?qs=SdqRYZZ9IxCIMp3bAQkD6Q==
Reactions: Kung Fu Panda
  • @ kingmudduck:
