You've brought up some good points to chew on. Good call on the mic jack conversion. I know I don't want to keep the RS mic, but a jack swap hadn't occured to me. You mentioned something about mic shielding; how would I go about that?
Yes on some Realistic radios I have seen them use a small pcb (behind mic input), others they have the DIN receptacle soldered directly into the main PCB, I think this is what you will find inside your TRC-474. If the jack goes directly into the main PCB you may have to get creative, and add a
wire with shielding for the audio line plus an extra cap or two on the rear of the 4/5 pin to chassis to help de-couple things.
On a TRC-431: The DIN receptacle is soldered into a small pcb with the with the factory chokes and de-coupling caps placed on it, for the conversion I simply reused the existing pcb, by adding wires in place of the original DIN pins, these wires extended a few inches longer to give me wiggle room during install. And I simply matched the pinout of the DIN plug to the desired "Uniden/Cobra" style pin out, and I'm able to use almost any standard CB microphone.
Another way to do it would be to mimic (or relocate) some of the components that are directly on the board but rebuilt in a "deadbug" or "manhattan" style free-floating construction off the back of the microphone input jack, closer to the *new* front panel.
This is all anecdotal, but what I can tell you for sure: How to go about it really depends on how that particular radio was designed, If you see ceramic capacitors from the metal frame to the pcb ground I would say you would be fine following a Cobra/Uniden 4 pin schematic.
[photo="medium"]4458[/photo] .
The TRC-474 may have a brother radio that was built by Uniden (usually 4 pin) in that case I'd copy the factory arrangement of the similar radio. Not all models sold by R.S. came from Uniden, but the ones that did... I can guarantee a huge chance exists the same radio was sold under a different model, with the same PCB inside.
An example of what I mean, the Realistic TRC-427 is basically just a Cobra 25 GTL/Uniden PC-66 without the mic gain control.
So I would copy the way the factory did it on the Cobra/Uniden and "clone that setup"
into the Realistic radio, this should work for you just fine. Not all Realistic TRC radios were made by Uniden; so in the end you will need to get creative! (You'll need a 4 or 5 pin female jack) the last Realistic I converted got a standard 4 pin jack, on some radios you may need to use a 5 pin!
Depending on your selected case size, perhaps you could simply buy an adapter instead (if room permits) that'd be a quick and easy way to use a more common mic.
From Wikipedia:
The term
harmonic in its strictest sense describes any member of the
harmonic series. The term is employed in various disciplines, including music and acoustics, electronic power transmission, radio technology, etc. It is typically applied to repeating signals, such as
sinusoidal waves. A harmonic of such a
wave is a wave with a
frequency that is a positive
integer multiple of the frequency of the original wave, known as the
fundamental frequency. The original
wave is also called 1st harmonic, the following harmonics are known as higher harmonics.
So round-about 27 mHz is the fundamental (or 1st harmonic), and the 2nd harmonic frequency is roughly around 54mHz, third order harmonics exist, and so on. For our purposes we like to keep the 2nd harmonic to a minimum, way down in the mud/noise floor as possible, the third order would not be an issue then. The higher in multiples of the fundamental you go, the weaker the signal becomes.
The factory service manual (not available for all models) explains the alignment procedure.
The point is we don't want our signal heard anywhere except the fundamental frequency.
From what you describe, that radio may have been "peaked and tuned". I have heard of radios causing these issues without power ("barefoot") because the 54 mHz TVI suppresion trap was fiddled with for an improper "tuneup"; the results (or so I here) were a lot of TV, radio, & computer speaker issues as you described, bleeding into other (much newer) devices.
A LPF will help block anything over 30mHz (depends on your filter) but the meter will show less output if the LPF was placed between the radio and meter.
(assuming the TVi trap has been fooled with.)
When some places "peak & tune" radios they incorrectly adjust or damage the 54 mHz harmonic suppression circuit, this causes the watt meter to show an increase in power. BUT I'd rather be clean, instead of showing a few extra "ghost watts" on the power meter. As the 54 mHz harmonic is measured by a watt meter (and added to the fundamental freq. power reading), but the added power is not even remotely on frequency. So any gains by doing this are false, and will lead to RFI/TVI issues!
In the wonderful world of 2-way communication I find that CB radio has more myths and folklore attached to it, than any other another 2 way service in existence. Peak & Tunes (crappy ones) are a subject for a whole another thread, but let's just say it is possible your radio may have been fiddled with in the past!
Not caring about possible splatter is always a negative attitude in radio, I don't feel that you want to splatter and it was a good call on using the LPF!
Unless you are interfering with the vehicles engine controls/electronics, you could in-theory get-by without a LPF in a mobile setup.
As a stickler (almost 11 meter purist) I 100% agree with Captain Kilowatt, if you are on the road and moving the issue could still be there but will not be as crucial as if in a base station (stationary) style operation.
If you pull the lids off the radio, do you see any coils that have been squished/spread into a slinky shape? Or a Brown/White cylinder with copper coiled around it, missing a ferrite core in the center?
Look towards the back of the radio, near the SO-239 antenna connector.
Also, if this is not going to be a base station unit when done.. You wouldn't need to concern yourself with a power supply, I was not 100% sure what direction this project is headed in when I mentioned buying a power supply. (Just run a 2 or 2.5 amp fuse in-line somewhere & you should be fine)
Also attaching a traditional s-meter to this radio will require some poking and prodding as I didn't notice this model uses an LED bar graph style meter.
Sorry for the long post!
Best Regards
-LeapFrog
