Al-80B no pate current/no output
tpknomad
Dec 8, 2010
I have had this amp for about a month now and it has been working fine.
Last night after using the amp it was in standby and I noticed the plate current in standby was sitting at 175?? Usually in standby this would be 0...
If I put the amp in OPR and key the radio the Plate current drops from 175 to 0. Grid reading is normal, power out is 20w to 0.
Re-tune or drive level adjustments do not produce any plate current??
Plate current stays at 150 until you key down and it goes to 0...
HV is normal ... any help would be appreciated///
