Hi,
I have the Alinco DR-600 2m/70cm cross band full duplex mobile transceiver.
The VHF squelch knob seems to have a minor problem; when I turn it to the most sensitive setting (like when you can hear all the white noise) the noise comes in and out and is not staying there.
Is there an easy fix to this to get the noise to stay on in weak signal conditions again?
I will try to get whatever data/multimeter measurements you need for further troubleshooting.
If not, thats ok, just wanted to see if there was a simple fix or not to these type of problems.
Skyler KDØWHB
Skyler KDØWHB
