I'm pretty new to the forum, as well as tube amps. I have an Ameritron AL-811, it still has the original 811A's, and has worked well till 3 days ago. I feed it with a Yaesu FT-847 and I do use the ALC line to limit the drive to 70W. Heres the problem, I tuned it up on 40m monthes ago and don't really use it on other bands, I turned it on and let it warm up for about 5 min, but when I keyed the mic to sign in to the net, my radio shut the power supply down. I had to turn the supply off and back on to get the radio back on. The radio seems fine, and amp will tune up and run normally on all bands except 40m, all bands will take full drive and generate about 550W output, but on 40m I can't push the plate current beyond 300ma or it shuts the radios power supply off... I'm figuring something is causing a higher than normal draw from the supply and overloading it because the supplies light stays on, just no output to the radio. only 40m is acting up, all other bands work fine. Any help is much aprieciated...... Kevin KC9OGB
