I dont have any pictures of my 40012 anymore, but it did ( do not know if they have changed anything) not have any thermal tracking ( diode across the transistor/on heatsink) so as the amp heats up the bias current would drift.
Exit13 has a thread here:
http://www.worldwidedx.com/home-brew/138726-x-force-amp-finished.html where he re-worked his amp to clean up the output.
Texas star has their problems as well, you have to remember these are CB style AMPs
My xforce amp had plenty of padding to allow you to drive the dog snot out of it, but as the peak numbers went up it would start to get raspy on SSB.
The power supply would pull down to about 17 volts or so under load.
I do not think they are still running the same transformers, but mine had taps on both transformers in the power supply that you could change to get the higher voltage.
Frank is the one who told me I could switch taps, but you really need all your ducks in a row if you start running the 2879s that hard or you will roast something.
Running the high taps and driving hard I could see over 1KW on a Palstar peak reading meter out of 4 2879s........
At that point one of the rectifiers failed.
Carl sent me new ones for no charge after I called and talked to him on the phone.
