Anytone 6666 new
No matter what mag mount I use or antenna I can't get the swr set radio says hi swr and there is no power out I know there is a safety in the anytone quad 6.I have a tram mag mount with 3 magnets on it tried 2 different antennas.and they check out with a DMM 0.00.I don't know what's going on
Have you been in the software yet? What's the swr cut off set at in the software? Stock the 6666 comes at like 30 so if it's protecting itself then there's something really wrong in the antenna system. You said above the sirio 5000 was working really well so something happened either in the coax or antenna
Don't have the cord to go into software if I remember I had to shut of the TSR in order to get power to set it I look see if I have a cord to look at software
Something is wrong with your antenna. If the antenna has no matching network then 0.00 on your ohm meter is a dead short. Do not use this antenna until you find out what is wrong. I suspect a plastic washer is missing in the mount. Are you measuring from center pin to shield?
