This is pure gold, thank you @BlueBeam! I am going to try this on my Ares 2.The band is worn off this diode but it is oriented banded end down and on the left, also I have settled on a 500 ohm resistor.
73 Panic Attack
The method I posted will not hardly do anything on the Ares2. Even with service menu access it does very little.This is pure gold, thank you @BlueBeam! I am going to try this on my Ares 2.
Thanks for the clarification, I was hoping that it would work on the Ares 2. I have not seen anything about the service menu yet.The method I posted will not hardly do anything on the Ares2. Even with service menu access it does very little.
I have since chose a different area to do NPC on this chassis even though the method I posted does wake up the other radios with this board it's next to useless on the Ares2. Has AnyTone leaked the service menu yet?
Hello I have one problem I have changed in menu 10 and 17 and do not get back to the correct number with the keys I have the latest version radio???AnyTone AT-5555 Plus V7 Service Menu Settings:
I started the service menu adjustments. I wrote down the first 19 items and adjusted only the 4 items mentioned above to get this radio swinging and modulating on AM. All other items are factory and not touched. I listed the factory setting and the setting I changed it to on those 4 items. Everything looks good on my testing equipment. I will report what kind of audio reports I get tonight locally. I will write down and then type into Excel the rest of the settings when I have time.
Thank you BlueBeam for the information.
Meny settings by cable???
Yes strange can only go higher can't turn all the way down to right number??? hope someone can help me because the radio is only 4 days oldUmmm.... what?
Try to be a bit more specific. Geeeezzzz. Tell us what you're trying to change, why, and exactly what is happening.Yes strange can only go higher can't turn all the way down to right number??? hope someone can help me because the radio is only 4 days old
I was just going to write down all the factory setting numbers and change them to what was recommended, but when I entered menu no. 10 and 17 and turned on the channel selector, it went up in number but not back down to the correct number. When I send with the radio sounds like I'm sitting deep inside a tube and talking now.Try to be a bit more specific. Geeeezzzz. Tell us what you're trying to change, why, and exactly what is happening.
I have no idea what settings 10 and 17 are. Seems like getting info from you is like trying to pull teeth. Try turning it to the right and see if it keeps going and starts over. You still haven't said what you're attempting to adjust. Sounds to me like you don't know, either SMFH.I was just going to write down all the factory setting numbers and change them to what was recommended, but when I entered menu no. 10 and 17 and turned on the channel selector, it went up in number but not back down to the correct number. When I send with the radio sounds like I'm sitting deep inside a tube and talking now.
I'll never understand why people feel the need to get into the service menu and start screwing with things. These Anytone radios work great right out of the box, so why mess with it. I guess for some people, if there's nowhere to insert the proverbial golden screwdriver, then messing with the service menu is the next best thing.......... And you can screw up the radio even faster than with the golden screwdriver !
