astatic antennas
S
santa55
Guest
hmmm i though i read somewhere that they were good antenns... but thanks for the info seamaster 111...and i'll keep that in mind about paying for the shipping...
santa
</p>Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=santa55>santa55</A> at: 2/21/05 5:55 am
Spiderman would a 5' wilson silverload work as good? i have a bit of a height thing going on...its mounted on the back bar of a day cab semi...8' 9" from ground to bracket then 5' up total 13' 9" i have to watch some low bridges in ill.. take care
santa cdx 275
</p>
Thanks Coax Killer...yes so far it works great but I always wonder if something might work just a little bit better...
santa
</p>
Tks Spiderman 5095...I do run my coax under the driver side of the cab and up through the door hinges... i use 18' of rg 142...the antenna is mounted about 4 to 6" behind driver on stainless steel grab bar...and mounting bracket grd. to frame...total height 13"9" and is 8" above top cab fairing and 3 to 4" above van trailer...Coax Killer did you see any difference on tx/rx when useing the 5' to 7' wilson silverload?
Thanks for all the help
santa
</p>
iv'e had one for 3 years now, the set screws rusted after the first winter' changed them for stainless steal ones. i didn't care for the windload as a mobile and my 6 year old wilson rx/tx/ better. i now use this for my local verticle on a home brewed ground plane. i range about 10 miles mounted 18 feet above the ground. swr is 1.4:1 on all 40 channels.
tks for the info. rfoverlord...i have a wilson 2000 with 10" shaft...but not sure if that's just long enough over the top of the cab...coil is just to the top of cab not over...antenna i mounted on the driver side mirrow...i could use a 15" lenght shaft if that might work better? or longer whip...
santa
    AKA- UDX122
