YouTube - HAM + CB Roof Antenna Tripod Install
Does everything look okay so far? Yes, I know I went nuts with the roofing sealant on the bolts...
3ft antenna tripod, lag bolted (3/8"x2") into 2x4s on the other side of the roof to help distribute the load, so it's not just threads in 1/2" piece of wood + a shingle holding the antenna in place.
4ft masts, currently two. Haven't decided if I want to do maybe three or four, and guywire it.
Planned:
Sirio 827 10/11m vertical on top of the mast, for working local CB / 10m.
10-80m dipole, ran from about 20 ft off the ground off masts attached to the fenceline, straight to the middle of the mast (Perfect distance). Perfect East/West signal.
2m J-Pole (MAYBE!)
Any questions? Comments?
Mind you though, I'm a poor college student. Here's some pics of my base right now.
The Heathkit DX40 still needs a bit of work to be in perfect working order. It's only outputting about 5w..I need to replace the 6146 final tube. Already replaced a few of the capacitors. Looking to get a Yaesu FT101 as my "official" HF rig. Currently, do NOT own a base/mobile 2M radio. All I have is my Yaesu FT270r handheld.
-Richard-
Planned:
2m J-Pole (MAYBE!)
-Richard-
