Bird 43 vs Radio Shack meter
Kirk
Mar 6, 2010
6
My Bird shows higher vswr than my radio shack meter. The radio shack meter matches the BIRD's power measurements. Is vswr different than swr?
No Vswr is swr. I would trust the Bird long before I would trust the RS meter. That being said I do have a Digital SWR/PWR meter from RS that is dead on with my Bird and MFJ Analyser.
How much different? If it's just a little bit, no huge problem. If it's a lot, then I'd start worrying. Either meter could be 'off'.
Since the Bird doesn't even measure VSWR, I assume you're using a chart to convert forward and reflected readings into VSWR?
