just get a good cross needle type meter and you will be happy, very easy to read, and they can tell you everything you want to know and maybe a little more, I loved MFJ-962 one built into my MFJ-962 tuner
Fancy.
MFJ Enterprises Inc.
Ok after looking at the links you posted (thanks) I think im leaning more towards the palstar or autek meters. They seem simpler and are much much cheaper. I dont need slugs either. Can someone explain how the cross needle meters work? I see one needle is forward power, one is reflected power. Where does SWR show on a meter like that? Also someone above suggested a meter that can read PEP. Can a cross needle meter read PEP? Is the power reading on the cross needle meter peak or average or both. Also, im guessing it is a powered meter? It dosent really say in the link.
If the radio is showing a 6 to 1 VSWR with the amp inline, there is definitely a mismatch to the input of the amp. One important part of this diagnosis is determining if this VSWR is bad only when the amp is inline or if it has to be on for the bad VSWR to show?
If the VSWR is only bad when the amp is in the operate mode, the input stage to the amp is not tuned correctly. If the VSWR is bad whenever you put the amp inline and it's off, the problem in the RF wiring through the relay inside the amp. Sometimes they don't use shielded wiring here and that wrecks the 50 ohm impedance.
Where did you order your Wm1 and for how much?
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
