Sounds like it might be time for a new radio unfortunately... If you cannot diagnose the problem yourself, then you would have to pay a tech to take a peak at it.. Not sure what that radio costs, but by the time you pay a tech and or whatever the cost is to fix it , you might be better off spending the money on a new radio.. Good luck.. Let us know how you make out..
Check the voltage on the gates of the fets. There should be a specified voltage in the tune up section. Should be no more than 5 volts maximum. If the voltage is too high that's what is blowing your fets. Many things can cause the voltage to be too high, open resistor or a shorted diode. If you give up my offer still stands!
Please advise me to what is a good replacement mic for my SR-497HPC... Answer: 497 is "wired like Cobra", so many choices available. That radio does not need a power mic, so purchase a stock "coffin style" mic with a decent cord, like the ones that Astatic uses. The Superstar DM-507 is my go-to. https://www.ebay.com/itm/3050474478...adANq91JSiEEnz8EGqPJRBloTgEyaVsBoCtoMQAvD_BwE $12.99 + .99 cent shipping.
